Ir para o conteúdo principal
Adaptador de alimentação CA para MacBook, MacBook Pro e MacBook Air. Utiliza um conector magnético de autoalinhamento que se desconecta com segurança quando puxado. Os carregadores MagSafe de primeira geração (2006-2012) possuem um conector em formato de L levemente mais espesso. Disponível nas versões de 45 W, 60 W e 85 W.
Source for replacement MagSafe cable
I've looked at the reviews for replacent MagSafe cables for my MacBook charger on eBay and Amazon and they are really dismal. Is there a source for QUALITY replacement cables? I'd like to do a repair that will last at least as long as the original.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
2 respostas
Pergunta mais útil
Here's the guide for doing it along with a parts source:
Substituição do cabo e conector MagSafe de 5 pinos do cabo de alimentação do MacBook
Esta resposta foi útil?
Pontuação 3
1 comentário:
I managed to completely destroy one Mac charger trying to replace that cable. But I did salvage the new cable. My plan is to next time split the charger body apart, cut the damaged cable just inside of its strain relief. Then install heat shrink to the two wires, solder the new cable to those, and then reassemble the charger case and "wings". This way I won't have to remove the charger from the bottom half of the shell or mess with the charger circuit board at all. I really think this is the way to go.
por Compartilhar
Sadly, Apple doesn't offer replacement parts for the AC adapter.
They look at it as a safety issues between what it takes to open the welded case and the possibility of damaging the computer.
Pontuação 2
Adicionar a sua resposta
John Lewis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 2,258
