Ir para o conteúdo principal
A cafeteira Keurig B77 é uma cafeteira de xícara única fabricada pela empresa Keurig.
Unit will not turn on
Unit suddenly will not function after working fine 1 hour ago. The touch button to turn the unit on will not light up and their is no display on the screen
Esta é uma boa pergunta?
Pontuação 18
1 comentário:
We have a problem about the same. Our power company installed a new transformer on our line and the unit worked prior to that then nothing we've tested the outlet and it's fine. Can we re-boot the unit?
por
Adicionar um comentário
5 respostas
no power to unit whats up ? is there i fuse somewhere
Esta resposta foi útil?
Pontuação 0
I have the same problem, just got this coffee maker. Worked fine for a day, then it started acting weird. It wouldn't brew every time I pressed the button. Then all the sudden it stopped working and the screen wouldn't come on. Ridiculous!
Pontuação 0
1 comentário:
I'm having the same issue. My unit is a couple years old. Where can I take it to be repaired? Is it completely kaput or repairable?
por
Defective on-off switch
Pontuação 0
1 comentário:
how do I fix that ?
por
My keurig coffee maker will not turn on anymore . I had just used it to make a cup of coffee ,for the next one it would not start.
Pontuação 0
Blue light Screen no writing on screen
Pontuação 0
Adicionar a sua resposta
Neil será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 22
Ao todo: 3,890
