Ir para o conteúdo principal
Tela - 7" 1024x600, processador quad-core MediaTek de 1,2 GHz, memória interna - 16 GB, RAM - 1 GB, sistema operacional Android - 4.2
white display with smashed screen
I have a white screen with a crack on the front as I sat on it. I can see parts of the display under it but no response to anything I have tried. Please could you help as I need this for my school work urgent. If I drag the top part down I can see it moving I also have the ability to unlock it but it is still the same screen. The display around the smash marks is black. Help is needed.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
The problem is both the LCD and digitizer are broken. You'll have to replace them.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Fiona Heaton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 564
