Ir para o conteúdo principal
O Asus Zenbook UX31A é um laptop lançado em junho de 2012. Ele é um membro da linha Ultrabook da Asus. Possui um processador Intel Core I7 de 3ª geração e uma tela IPS Full HD.
ZIF Mainboard-Touchpad cable lock broken
Hello,
The cable lock/socket hinge on the motherboard of my Zenbook broke off after I misjudged it for one with a slide lock and pulled it out. Afterwards I also lost it.
Now obviously the zenbook has no connection to the touchpad.
Here's a picture of the connector without the hinge: http://i57.tinypic.com/2vxhs3s.jpg
How do I fix this? Can I replace the connector? Can I fix the connector? Could I maybe swap the connectors (i.e. put the working connector from the touchpad on the mainboard and then replace the touchpad)?
Its such an annoying mistake and I feel really stupid I hope you can help me.
best regards Alex
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Try using a hot glue gun. The glue is too thick and dries too fast to spread into the actual connection. I also doubt it'll melt any of the cable sheathing, but just in case, heat up a drop, wait a sec or two and see if you can mold it into the joint with your fingers.
Esta resposta foi útil?
Pontuação 0
Hello ledieu,
did you find a solution for your problem?
Same happened to me just know.
Would be great to hear from you!
Pontuação 0
No I haven't
But if you try the hotglue I'd like to know if and how well it works.
For me I have it half fixed with tape and folded paper to hold the cable in the socket
But sometimes the connection drops
Pontuação 0
Adicionar a sua resposta
ledieu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 1,616
