Upgrade to IPS 768 screen, which panel?
I'd like to upgrade my x202e Vivobook to a 1366x768 IPS screen. I know Asus has them in some models, so I'm wondering which panel I should get that will work with my machine.
Esta é uma boa pergunta?
erniekeller, since it is not a direct replacement, this could be a hit or miss. You have to make sure that the replacement panel uses the same connections as well as the same signals. For that you need a datasheet of the current display as well as a datasheet for the replacement you choose and compare those.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 553
