Ir para o conteúdo principal
Renascimento moderno do automóvel clássico de John Cooper, fabricado pela BMW.
How can I replace a glove box door?
Glove box handle broke and I fixed it but have no idea how it mounts. Is there an illustration somewhere that shows how it mounts?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
here (click) is a link to mini2.com.
there is a pdf and some instructions
good luck
Esta resposta foi útil?
Pontuação 4
1 comentário:
Great info source. + Ralph
por
I recently replaced mine. Couple of screws across the top, two on either side, and one torx in the back. There's a vent tube that you place in after the replacement, and the valve connection for this you have to transfer from the old box (this was a very tight for both the old and new box so be careful, it's twist-lock, a lot of wiggling and cursing). You also have to transfer the light assembly, which removes downward into the box.
Imagem
Imagem
Imagem
Pontuação 2
Adicionar a sua resposta
Richard Capuozzo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 19,522
