Ir para o conteúdo principal
O Sony Ericsson Xperia Arc S é um smartphone com Android 2.3.4, equipado com um processador Snapdragon de 1,4 GHz e HSDPA de 14,4 Mbit/s.
How to increase the ram speed
how can i increase the ram speed and increasing internal memory
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
2 respostas
Go to settings and check running applications. Check if any unwanted application is taking up RAM space. manually force close it. Your device should work fine.
You can also ROOT your device, which means getting an Admin access to your device core file system. This allows you to remove any apps that you think is taking up RAM spaces.
!! ROOT is risky, since it is getting you an admin access to core files, any alteration or modification can brick your device." If that happens you will loose the warranty. (If you are having any)!!
Esta resposta foi útil?
Pontuação 0
2 comentários:
Is there any way to make the applications not starting up again when rebooting the phone?
por
This can be done on settings i am sure of it. Go to applications and have a look.
por
I was Like You root your phone and install link2sd remove original system apps or
install grinify and freeze apps this is better if you didnt root
apps like facebook will take 80-90 mb ram!!!
Pontuação 0
Adicionar a sua resposta
madhavan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 1,847
