Ir para o conteúdo principal
The 2014 edition of the Kindle, part of the 7th generation, includes a touchscreen and same form-factor as the Kindle Paperwhite, but lacks the backlight.
20 Perguntas Visualizar todos
Why won't my Kindle 7 turn on?
My Kindle 7th Generation won't turn on despite pressing the power button. Why is this?
Esta é uma boa pergunta?
Pontuação 11
Adicionar um comentário
5 respostas
Pergunta mais útil
Hard Reset your device by holding the On/Off button 40 seconds or until you see a picture of a tree with a boy reading underneath it. If the Kindle doesn't boot set it to charge for about 2 hours or even better over night and try hard resetting the device again. If this doesn't work you can assume that it's a hardware issue and proceed to contacting client service.
Esta resposta foi útil?
Pontuação 6
2 comentários:
Worked first time, very good and thanks.
por
Worked perfectly following your suggestion. Thanks
por
Well, Mitchell, there are a lot of reasons why this could be. The most common answer is the Kindle simply isn't charged. Find a micro USB cord and plug your kindle in.
Other reasons why your kindle won't turn on are more serious problems such as battery or motherboard failure. Don't fret because you can figure out how to replace the battery and replace the motherboard here!
Be sure to head over to trouble shooting to narrow the problem down!
Imagem de Kindle 7th Generation Battery
Guia
Kindle 7th Generation Battery Replacement
Nível de dificuldade:
Moderada
15 - 20 minutes
Imagem de Kindle 7th Generation Motherboard
Guia
Kindle 7th Generation Motherboard Replacement
Moderada
20 - 25 minutes
Pontuação 1
Begin by charging the device with a micro usb cable. It may just be that there is not enough battery life to support the device and permit it to turn on.
Pontuação 0
The other thing I realized and this is something I learned the hard way, is that if there was a mass of liquid in the device’s ports(anyone of them) the device will not turn on. I recommend you calling Amazon Customer Service to get the kindle fire 7 repaired or replaced if needed. There is also a one year warranty for the device. I had to get mine replaced and they sent me a kindle fire that has a dead battery icon and is incompetent of charging. So, if you are in real need of getting a kindle fire, just go to target or walmart and buy a NEW one not a refurbished one.
Pontuação 0
Don’t worry. If your Kindle won’t turn on try these steps given below and fix your issue.
Hard Reset your device. The first is to hold the On/Off button 40 seconds. Until you see a picture of a tree with a boy reading underneath it.
If the Kindle doesn't boot. Set it to charge about 2 hours or even better overnight. Try hard to reset the device again.
If this doesn't work you can assume that it's a hardware issue and proceed to contact Kindle support number.
Pontuação 0
Adicionar a sua resposta
Mitchell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 15,643
