Ir para o conteúdo principal
This children's learning tablet was manufactured in 2013. It has a black exterior, and has a medium sized X on the back. Model number: XO-780. No factory recalls.
Why isn't my tablet turning on?
I pushed the power button and nothing happens.
Esta é uma boa pergunta?
Pontuação 6
4 comentários
my USB/charge port is loose. I know why it won't turn on. I need to know how to get it repaired.
por
y is not truinng on
por
I push the power button and it doesnt come on.
por
Why my vivitar tablet wont turn on
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @randolphmora123,
Does the tablet show that it is charging when you connect the charger to it?
What % of charge is the battery icon showing when you try to charge the battery only and not switch on the tablet?
If it shows that it is charging allow it to fully charge and then try turning it on.
If it still won’t turn on after it is fully charged, can you start and use the tablet with the charger connected and switched on?
If so, then the battery may be faulty and needs to be replaced.
Esta resposta foi útil?
Pontuação 3
For more information about your XO Tablet please go to the following website: http://xotablet.com/
Also, you can check out the troubleshooting page for this device!
Vivitar XO 7 Troubleshooting
Pontuação 0
Adicionar a sua resposta
Braanah Craig será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 2,094
