Ir para o conteúdo principal
Ajuda para reparo e resolução de problemas do Memo Pad ME172V, um tablet de 2013 fabricado pela Asus.
stuck no usb cable connected
help...my memopad me172v stuck "no usb cable connected" i try all trick ..but not working....
1.sd card 4gb (fat32-cleandata.zip)
2.rkandroid
3.easyflasher
please help
screen shot - connect my computer
unplug my computer
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Solução escolhida
Before doing a factory reset open the tablet and disconnect the battery for a few minutes and while the batteries disconnected hold the power button down to remove any static discharge in the memory. If theres no joy after that then do the reset but remember you will lose all your data and apps . this reset you to factorey like it was when you first got it. This video shows how to open the back and disconnect the battery .you dont need to remove the battery just disconnect it.
https://www.youtube.com/watch?v=lcKIPddf...
Hope this helps
Esta resposta foi útil?
Pontuação 3
you need to reset it .. HARD RESET or just continue to root you tablet
you need to download some root kits (find it on google) and turn on you tablet like Volume Up + Power button
and follow the instructions
Pontuação 2
1 comentário:
Thank you ujojedobry, great advice. worked for me!
por
My Asus tablet stuck on no USB connected how to fix it
Pontuação 0
Adicionar a sua resposta
zeckleus será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 35
Ao todo: 11,715
