Dell inspiron N5010 making 8 beep with no display
8 beep sound problem is generated in my laptop (N5010) 6 month before. After diagnose and replace screen it resolve but same problem occurred now what was i do.
Esta é uma boa pergunta?
Kunal, what happens when you connect an external display? Yes, it is most likely a bad LCD. Even replacement can fail prematurely.
" 8Beeps is usually a LCD or cable failure. Try this first :
"If the LCD on the system does not show any display, here are some basic steps that you can perform:
Remove the battery and AC Adapter from the laptop and press the power button down for about 10-15 seconds to release flea power.
Power up the system and then press the F12 key during the boot process to get to the Boot Menu, if you are able to see the display.
It may be necessary to repeatedly press the key during the start-up process.
Use the up and down arrow keys to select <Diagnostics> on the menu and press the Enter key.
Or
Hold down the Fn (function) key
Power on the notebook
You should then see the Dell logo screen with the message 'Diagnostic boot selected' in the top corner.
You can then release the keys
While the LCD BIST test runs, the LCD is operating on its own, free of the video controller, which may be discrete (a video card) or on board (on the system board). The test allows you to distinguish an LCD panel problem from a problem with the controller. If the colors are displayed across the screen without a problem, then the issue is not with the LCD."
Esta resposta foi útil?
Hi all,
i am using Dell N5010 Laptop and i am hearing 8 beep sound while turning it ON. If i am connecting external display it shows display but not as usual.It shows like broken Display, but my Laptop didnt got broken, I am Thinking that it causes because of cable failure, Please suggest me some solution for that.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 191
