Ir para o conteúdo principal
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
189 Perguntas Visualizar todos
I like to know how to turn on my MacBook air without keyboard
hello I am very proud of this website I looked everywhere I have not found I like to know how to turn on my macbook air model A1370 mid 2011 without keyboard
Esta pergunta é pertinente?
Pontuação 3
1 dos comentários
You are looking for the power pads on the A1370?
por
Adicionar um comentário
2 respostas
Solução escolhida
men, use the power on pads. Bridging those two pads should power on your MBA unless there are other issues with it.
Esta resposta foi útil?
Pontuação 8
1 dos comentários:
This was super helpful. Thank you ❤️
por
Hey men
What is probably the easiest way to do this, would really be just to remove the MacBook’s battery. If the battery isn’t present the power button becomes disabled because your power runs from the charging brick the MacBook came with. So if you connect the MagSafe connector, the Mac turns on instantly. If you disconnect it the MacBook kills because there is no power.
Hope this helps!!
Pontuação 2
Adicionar a sua resposta
men será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,863
