Ir para o conteúdo principal
O Nokia Lumia 710 é um smartphone com Windows Phone e tela sensível ao toque de 3,7".
fix network connection problem
My phone has Network Connections Problem. What do i do?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
hi, Louisa, i found some information that may help you.
1. downloaded the latest version of Network Setup (Nokia app) from marketplace. I had to uninstall version 1.1.x as before installing newer version as for some reason it was not letting the update through
2. ran the network setup and added new APN airtelgprs.com and MMS APN(dont know what this is) also as airtelgprs.com
3. Now it gave me two networks to choose from AirTel and airtel. I chose airtel (Do not ask me why)
4. switched off the data connection under settings>mobile network (again dont ask me why)
5. switched off the phone and removed battery and also sim card
6.put back the sim and battery and switched on the phone
7. Switched the data connection back on under settings>mobile network Voila,, it worked.
no Nokia care or Airtel needed.. no factory reset needed...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Louisa McGoon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 17
Ao todo: 3,767
