Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1624 Perguntas Visualizar todos
Spanned screw, how to remove them?
Hello I was following the guide for updating my mid 2012 13" Mbp to a dual drive when I spanned the screw of the optical drive due to a lack of space between the screwdriver and the optical drive itself.
Any tips of how to remove them?
Step 14
Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive
Esta é uma boa pergunta?
Pontuação -1
2 comentários:
What do you mean by 'spanned'?? Did you break off the head of the screw or did you strip-out the head so a screwdriver can't turn the screw? Also did you use the correct screwdriver?
por
Jesus that's a late reply by my side thought nobody ever replied.
Head of the screw was broken. Yes I used the right screwdirver but both screws closer to the outer edge of the laptop got borken. Got to buy a dremel to remove them.
Thanks!
por
Adicionar um comentário
1 resposta
You might be able to use one of these sets from iFixit store or similar:
Precision Screw Extractor Set
Imagem de Precision Screw Extractor Set
Produto
$24.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
andreabonomelli será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 506
