Ir para o conteúdo principal
O ZTE Boost MAX N9520 possui uma tela IPS HD de 5,7 polegadas com 4G LTE e Android 4.1.
screen touch does not work after replacement?
I replaced the screen and digitizer and the screen comes on but touch doesn't work. I've checked all connections twice. What could it be?
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Jeyson......did you end up fixing this problem??
por
I have the same issue. My ZTE zmax pro z981 screen broke and I bought 2 new screens and after I put new screen it lights up but doesnt respond to any commands
por
I have the same problem except mine's a ZTE n9521 screen not responding to touch
por
Adicionar um comentário
1 resposta
Solução escolhida
jeyson, if you are sure that all your connections are properly seated, I would contact the vendor and replace the assembly once more. Sadly enough, it is not uncommon to receive a bad digitizer. Of course, you always want to double check your work, check to make sure that there are no bend or broken pins on the connector.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jeyson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 26
Ao todo: 1,626
