Ir para o conteúdo principal
O primeiro tablet da família Acer Iconia Tab B1, o Acer Iconia Tab B1-A71, foi anunciado em janeiro de 2013.
Why the screen show White?
My Acer got white!! I was just playing some music, then i lay it down on the couch and went for something. When i returned the screen has got white and there was a crack in The middle, (not really, but it looked like an inside one ). But there was a black spot too. I turned it off and it turned black. Then i again turn on, but the screen appears as white ,black spot,and crack as it was. I tried to pull the notification bar. A sketch of bar appears but no icons or nothing. Help me please.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Did you sit on your tablet? Or did it drop when you were away? Anyway, the fact is your tab lcd display was damaged.
Esta resposta foi útil?
Pontuação 2
2 comentários:
SO, should i have to change the lcd screen? And my sister was there too, according to her, the tablet was there laying, and it didnt even fall. She haven't lied. However, what to do with the tablet, and how to fix it??
por
You mentioned that your tablet had cracks, spots and blank screen, these are all hardware issues not software issues. A replacement display can fix it. If you'd like to DIY repair it, this is the part: http://www.etradesupply.com/acer-iconia-... and this is the guide Substituição da tela LCD do Acer Iconia B1-A71
por
I have the same problem but my screen was already cracked
Pontuação 0
Adicionar a sua resposta
Asad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 2,707
