My compaq laptop is not connecting internet.
my Compaq laptop is not connecting to wireless. i think my wireless card is broken and somehow its not connecting to wireless.
Esta é uma boa pergunta?
I understand that your computer will not connect to the internet.
What message are you getting when you try to connect?
Do a hard reset.
Turn the computer off.
Remove the power cable and the battery.
Hold down the power button for 15 sec while booth power sources are removed.
This should reset the hardware in the computer.
If you’re still not able to get online, go to device manger, uninstall the wireless network adapter and restart the computer.
This will uninstall and reinstall the driver for the wireless card.
Here is a link that will show you how to get to device manager.
Let me know how everything goes.
If your still not able to get online, go to device manger, uninstall the wireless network adater and restart the computer.
here is a link that will show you how to get to device manager.
As you turn it back on tap the F10 key. This will load BIOS setup utility.
Press F9 to load defaults.
Press F10 to save and exit.
When the computer boots back up, check to see if everything is working.
Esta resposta foi útil?
Have an Internet connection but cannot access the web on my Presario 2500
The Presario 2500 runs Windows XP which is quite old unless you've upgraded the OS to something newer or using a newer web browser that supports the current web HTML 5 standard.
I tried both ways nothing, I know theres another way by opening the bottom and taking the tiny card out and replacing it, this happened before, only I forgot how.
Hi @ Cherie Smith,
What is the model number of the laptop?
Can the laptop "see" and connect to the router OK?
Did you try the Win 7 troubleshooter to see if it could fix the problem?
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 36
Duração total: 15,679
3 comentários
Can you give us more here... How about what model of Compaq laptop you are using and the version of Windows you are running. Do you have a wireless router which other systems are able to access and have you compared their setting with your systems?
por Dan
Wireless router, window 7 compack laptop
por Cherie Smith
Guys I have windows 8 ore 10 and a compaq laptop. And first he got network with the wireless adapter. And shortly after that he kicked me out and could not found any wireless networks around. And on the f12 is a wirlisbutton but he don't chance from color. And if I press fn button with f12 then he go's like in a airplain mode. Wtf is wrong with it
por xAdr3 N4Liin
