Ir para o conteúdo principal
Lançado em junho de 2013, o Galaxy Mega é um smartphone de 6,3 polegadas que apresenta uma tela de 720p, processador dual core e uma câmera de 8 MP.
touch screen still dosent work
I dropped my phone and cracked my digitizer. Got it replaced and the phone worked fine. Then one day I updated it and ever since then my touch screen no longer works again. Bought another digitizer but still no response.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Tabita,
I'd try the following steps and test the phone after each step:
1/ Clean the screen connector on the board using a cotton swab dipped in 90%+ isopropyl (rubbing) alcohol.
2/ Reset the phone to factory settings. Hope you have a back-up. It is usually done by pressing and holding home button + power button together until the phone restarts (google it). Then choose cache wipe, then choose reset to factory settings.
3/ Dis-assemble the phone and examine the board using a magnifying glass. Look for anything missing/broken/damaged/part removed. If you see anything, take a picture and upload it here. Or if you don't want to do this step, ask a professional to do it for you.
Let us know what you find out.
Good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
tabitha everette será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 439
