Ir para o conteúdo principal
O laptop Gateway P5WS0 também é comercializado como um laptop Packard Bell em alguns países. O P5WS0 faz parte da série NV da Gateway e pode ser identificado pelo modelo NV57H58u.
How do I replace the keyboard?
How do I replace the keyboard on my laptop? I know that there is a tear on the left shift key pad that I found after removing the key to clean a sticky substance that I thought was the issue.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
how would ou clean under the trackpad on this laptop? i have the same one and im wondering cause i need to clean mine
por Compartilhar
Adicionar um comentário
1 resposta
Hi Hurley,
As far as i know with the knowledge of the same model but from Packard Bell this laptop has sort of a "unibody" like a macbook.
U would have to remove the complete top cover by removing the screws sitting at the bottom and lift the top cover up as a whole to get to the keyboard.
Mind you that most of the times these top covers are extra mounted with clips so it might take a bit of effort to remove it. I would suggest to start from the front (the side of the touchpad) and move forward towards the back.
Hope this helps you in any way.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Hurley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 1,512
