Ir para o conteúdo principal
The HP G62 is a laptop series produced by HP. G62 laptops are identifiable by the model number G62-XXX-XX, and endings vary depending on options and seller.
33 Perguntas Visualizar todos
All whites areas on the screen is Turquoise?
Please can someone help me with this, My laptop is booting up fine and all, from the boot up you can see that even the bois text, booting text is turquoise?
I have looked at the GPU all looks fine and the ribbon too.
I have the 1Gb dedicated GPU card in this G62
Update
Thank you yes i did connect to external screen it worked 100%, so replacing the screen now lol
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
rudolf, connect an external monitor and see if it displays properly. If it does, you know it is the LCD that has failed. If the external monitor displays the same problems, your GPU is having problems.
Esta resposta foi útil?
Pontuação 1
1 comentário:
and what if the problem is the GPU?
por
Adicionar a sua resposta
Rudolf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 447
