Ir para o conteúdo principal
Xserve is the name of Apple's 1U rackmount line of server computers. When the Xserve was introduced in May 2002, it was Apple's first designated rack-mounted piece of server hardware.
Why does the RAID reinitialize after restart?
I have a RAID 5 setup with 3, 1TB SATA hard drives on an XServe. Every time i restart the system, whether for updates or anything, it always detects "disorderly shutdown without battery backup" and reinitializes the RAID. The server still functions during this process, but i cant imagine its a good thing. Anyone have any ideas??
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
I would suspect that the RAID battery (similar to CMOS battery only usually larger) which allows the configuration to be stored has died. I would look for the battery (sometimes they are primary lithium coin cells and sometimes rechargeable NiCd/NiMH) and determine if it needs replaced. Remove the battery and check it with a voltmeter. Anything under 3V for lithium and under 1.15V for NiCd/NiMH (per cell) is probably dead.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
cedarskier5685 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,797
