Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
What can I do about a scratched camera lens on iPhone 4?
Whenever I take pictures with the back camera on my iPhone 4 the pictures are very foggy. I can see scratches when I look at my lens. I was wondering if anyone had any tips on what I could do to remove the scratches and whether or not I can fix it myself.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Check my answer. The easiest and quickest method. :)
por
Adicionar um comentário
5 respostas
Solução escolhida
Like Eric said, if you are looking at the back of the iPhone without opening it, and that's where you see the scratches, use this guide to replace this part (be careful to pick the right color).
Esta resposta foi útil?
Pontuação 3
Hi Luke,
The easiest, quickest and probably the cheapest solution would be to replace your back glass.
Pontuação 2
I have the same issue. But I got a trick. It didn't solve the issue but it's now greatly different.
I put a transparent "scotch" tape on the lense glass. That is now amazingly fine quality photo shooter than before. You must try this before paying even a penny.
Pontuação 2
1 comentário:
This worked Great! Thank You
por
of couse,you can fix it yourself
Pontuação 0
Cover the entire scratched lens with Vaseline by the help of your finger. Gently wipe off the Vaseline with a microfiber cloth. Make sure your finger and the microfiber cloth are clean. Apply some screen polisher or scratch remover to the scratched camera
Pontuação 0
Adicionar a sua resposta
Luke walker será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 11,100
