My samsung s2 is not turning on only logo keeps flashing
My samsung s2 got dead n is not turning on after charging only logo keeps flashing
Esta é uma boa pergunta?
Have you tried doing a hard reset to restore the phone back to factory settings?
The procedure does and will delete all files and downloads that are on your phone.
How to do a factory reset:
1) Turn the phone off. If you can't, remove and reinstall the battery
2) With the phone still turned off, hold down the Power button+Volume up+Menu buttons at the same time for about 10 seconds.
3) Scroll down and select 'Wipe Data/Factory Reset'.
4) Select 'Yes – Delete All User Data'.
5) Select 'Reboot System Now'.
Esta resposta foi útil?
this method is not working to reset my samsung gallaxy s2.
there any other way using hardware support
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 2,573
1 comentário
my samsung s2 is not turning on
por Neang Nen
