Ir para o conteúdo principal
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Perguntas Visualizar todos
Replacing a Magsafe "L" connector with a "T" connector
Hello All,
I own a late-2008 13" Macbook Unibody. I tried to replace the "L" connector of the Magsafe charger with a "T" connector following the instructions in one of the step-by-step guides in IFixIt but the result was not successful. Even when not connected to the Macbook, the light on one side of the connector remains bright green all the time while the light on the the other side is a faint green. When I connect it to the macbook the battery does not seem to charge and does not power up.
Any ideas?
Thank you in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Best to just replace the compete AC power adapter Vs trying to fix the MagSafe connector. Most of the time the splice breaks down and the. Causes other problems.
Esta resposta foi útil?
Pontuação 2
From your description, I guess you have a defective replacement MagSafe connector. In a proper working MagSafe connector, indicator lights are OFF while not connected to MacBook.
Pontuação 0
Adicionar a sua resposta
Dimitris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 492
