Ir para o conteúdo principal
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120 Perguntas Visualizar todos
Why wont my tablet power on?
Tablet pluged into charger but still wont power on.
Esta é uma boa pergunta?
Pontuação 9
3 comentários
Have you tried using a different charger or using a different outlet?
por
yes and sometimes it starts, but goes off after 10 seconds
por
On my old Tab 2, if I leave the power jack plugged in it seems to cause a malfunction with the screen so I unplug it when using it, see if that is the case, to eliminate possiblities.
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Yes, I have tried that many of times but it still did not work, but I believe it has something to do with the inside of it or either the charger port.
Esta resposta foi útil?
Pontuação 1
I have tried all of that even have brought a new charger and tablet still not working.
Pontuação 1
try to leave your tablet plugged in for the day making sure the chrging coard is plugged into the wall corectly and that its connected to the tablet all of the way i had the same problem with mine
Pontuação 0
When I plug my tablet up it won't do anything and it's not even a year old since I bought it
Pontuação 0
2 comentários:
I want to be able to use my tablet again or does it still have a warranty
por
I need to know if I still have factory warranty on my tablet
por
Adicionar a sua resposta
richmondmicheal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 21
Duração total: 1,731
