Why wont my tablet power on?
Tablet pluged into charger but still wont power on.
Esta pergunta é pertinente?
Yes, I have tried that many of times but it still did not work, but I believe it has something to do with the inside of it or either the charger port.
Esta resposta foi útil?
I have tried all of that even have brought a new charger and tablet still not working.
try to leave your tablet plugged in for the day making sure the chrging coard is plugged into the wall corectly and that its connected to the tablet all of the way i had the same problem with mine
When I plug my tablet up it won't do anything and it's not even a year old since I bought it
I want to be able to use my tablet again or does it still have a warranty
I need to know if I still have factory warranty on my tablet
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,695
3 comentários
Have you tried using a different charger or using a different outlet?
por Katherine
yes and sometimes it starts, but goes off after 10 seconds
por PAUL WILSON
On my old Tab 2, if I leave the power jack plugged in it seems to cause a malfunction with the screen so I unplug it when using it, see if that is the case, to eliminate possiblities.
por Mark Hayward
