Ir para o conteúdo principal
What is best way to clean dirty ports?
Dust/dirt gets into the charging and jack ports and eventually disrupts the contacts for charging. What is the safest way to clean these? I heard there is a special vacuum for this, and other suggestions are to use a small brush which doesn't really get all of the dirt. Suggestions please?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
5 respostas
Solução escolhida
The headphone jack is cleanable easy enough with a q-tip with most of the cotten pulled off so it can fit in the port. You should use 95% and above alcohol as the cleaning agent.
The charge port is tricky to try to clean with a q-tip. So don't use a q-tip to clean that port. Pressurized air is the best way to clean this port.
Of course you want to do your maintenance while the phone is off less you cause damage.
Esta resposta foi útil?
Pontuação 4
roll scotch tape into a cone shape. stick small end of cone in phone headphone or charging port. I get lots of lint out every few months.
Pontuação 3
Dear Q.,
I cleaned my iPad charging port by taking a Colgate Wave Sensitive toothbrush and brushing in the port; after a dry run, I lightly covered the toothbrush with hydrogen peroxide and shook off the excess, then brushed inside the port to clean it the rest of the way.
I don’t know if using hydrogen peroxide was good or not, but it seemed to help clean the port a lot more: Not having disconnect problems with the port now.
Take care, With love Through God and Jesus and The Holy Ghost,
Pontuação 1
1 comentário:
YES!!! GENIUS! I did the hydrogen peroxide with a GUM soft pick after other options failed! PERFECT, whew, I saw instructions to try to help the battery, looked complicated, SO happy this worked!!! THANKS! Jesus love received, amen!
por
Dear sir
i m facing to my iPhone 6 plus charging ports.my mobile fall down in desert some dust go inside into the charging port.so now i want to plug my charge cable that is going inside.so please help me
Pontuação 0
3 comentários:
Use compressed air or use blow into it
por
Carefully watch the breathing of your camel. After he exhales, push the charge port against his nostril and pinch the flaps closed along the sides of the phone. Hold phone tightly so the ensuing vacuum doesn't pull phone deep up his nose. Immediately remove phone before the next exhale or you'll have to start over. My reindeer have killed a few of my phones that way- I'm getting old and slower. Signed S. Claus
por
@unicorn9 ...
That is a disgusting & racial response!
Shame on you! I bet you call yourself a good Christian too!
por
my iphone port is burnt so what to DO?
Pontuação 0
Adicionar a sua resposta
Jacqui Marlin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 35
Últimos 30 dias: 127
Duração total: 92,929
