Ir para o conteúdo principal
O Xbox original é o primeiro sistema de videogame amplamente popular da Microsoft. Ele tem uma carcaça preta facilmente identificável com a inscrição 'XBOX' na parte superior e frontal. O reparo é fácil com ferramentas comuns.
How to factory reset entire system
My xbox from 2004 is saying that there is nothing on the hard drive but it has minimal space available and if i delete everything that I have on it I still only have a few hundred blocks available instead of the 50,000 it is supposed to have. Is there a way to completely reset the system to factory settings so there is not anything left on the system or is there some place I can take it to try and get it fixed? does any one even do xbox repairs anymore?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
http://www.se7ensins.com/forums/threads/...
Here you go. Warning though, this procedure is fairly lengthy and requires certain tools. It seems to be exactly what you were looking for though.
Good luck.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jody será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 14,467
