Ir para o conteúdo principal
O Microsoft Wedge Touch Mouse é um mouse ambidestro lançado pela Microsoft.
Stuck at step one
I had a corroded battery and need to clean the contacts. This post has detailed steps but I can't get past step one.
The cover just will not come off. I can easily pry up the edges but it feels like there's something in the middle of the top plate that's attached and I don't want to break the mouse.
Step one mentions about moving the pick tool along the edge towards the battery cover and mentions a pin I believe. This just doesn't seem to work and I don't know what to do next.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Steve,
That would be a cable which is connected there. It has enough length that you should be able to separate the two covers if you do it firmly/gently/controlled. Just realised your questions is from 2014. Hope you figured it out.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Steve será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 702
