Ir para o conteúdo principal
This Power Mac G4 has Mirrored Drive Doors.
80 Perguntas Visualizar todos
Pergunta encerrada
What is the best method of removing scratches from the case?
I have purchased a PowerMac3,6, (MMD G4). The tower's case (not the doors) has a number of fine scratches, some are deeper than others. What is the best method to buff out these scratches while keeping the case's mirror-smooth finish?
Thank you,
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Wil, are we talking about the Acrylic sides?
por
Adicionar um comentário
2 respostas
Solução escolhida
Wil, fine scratches can be removed with a mild abrasive polish such as Novus #2, or Novus #3. Heavier scratches, such that you can feel with your fingernail, will require some elbow effort to remove with a bit of sanding and buffing. A series of grits (150,400,800) followed by a buffing wheel and available buffing compound, this should restore your case. Check on here to get an idea of how its done. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you. That is more or less what I was thinking.
por
Pergunta mais útil
I would honestly just get a new case, they are not that hard to instal if the scratches are that bad. If they are not some Pledge works great.
Please mark me up if this helps : )
Pontuação 2
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 790
