Logic board fuse blown
Hello i think i must have blown that fuse those two screws is there a way to fix it
Esta é uma boa pergunta?
Mtaka, that is a Diode. It is a RCLAMP2402B diode and can most likely be replaced. If you have never soldered an SMD device, you could just replace the MagSafe DC in board. runs around $10 to $15USD board
Esta resposta foi útil?
...and many pins seems to be damaged on the LVDS socket. Could you post a close up pict of this socket and the LVDS cable connector end ?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 448
