Ir para o conteúdo principal
Um relógio de luxo analógico com tema de aviação da Breitling.
removing the bezel safely
How you you remove the bezel of a Breitling Navitimer Safely?
I heard there are screws holding the bezel down. hoo do i find these screws?
the gap between the bezel and case can barely fit a piece of paper. i can't get a knife in there. i plan to use a razor blade and see what happens.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
Again I repeat don't try to use any blade as it could be held be three screws inside if its a later Navitimer.
Whereas the earlier 806 model can be lifted from outside with a proper Watchmakers blade.
Kind Regards,
Tony
Tony Arnold {Director}
arny@helios-electronics.com
Esta resposta foi útil?
Pontuação 1
It depends on the model number etc
kind Regards
Tony
Pontuação 0
Don't use a razor blade, the edge could break and send shards into sensitive tissues, like your eyes. Yikes!
A watchmaker's tool or iFixit's Jimmy tool would be better.
Imagem de Handy tool for opening electronics.
Produto
Jimmy
$7.95
Pontuação 0
Time problem
Pontuação 0
Adicionar a sua resposta
han será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 14
Últimos 30 dias: 55
Ao todo: 3,383
