Ir para o conteúdo principal
Cen-Tech Seven Function Digital Multimeter . Model number 90899.
8 Perguntas Visualizar todos
Why won't the screen show any readout?
I want to use my multimeter to test a battery. The banana plugs are attached and cords are attached to the device, but the screen is not reading anything. My device is turned on and seems to be functioning otherwise.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
The reading screen is either broken or malfunctioning. You may need to replace the screen. See screen replacement guide here. If this does not seem to fix the problem, you may have an issue with the motherboard. Click here to see how to replace the motherboard.
Imagem de Cen-Tech Seven Function Digital Multimeter Mainboard
Guia
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Nível de dificuldade:
Fácil
5 - 15 minutes
Imagem de Cen-Tech Seven Function Digital Multimeter Screen
Guia
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Fácil
10 - 15 minutes
Esta resposta foi útil?
Pontuação 0
I'm all for fixing stuff and keeping it working, but Harbor Freight literally gives these meters away. They're not worth fixing. i have a stack of spare ones still in the package waiting to be used.
Pontuação 0
Adicionar a sua resposta
Anna Kihm será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 10
Duração total: 1,677
