Ir para o conteúdo principal
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
O que você precisa
  1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Position Device: passo 1, imagem 1 %32
    • Place the meter face down, and the back panel and screws can be seen.
    Pergunte ao FixBot
    Comentar
  2. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: passo 2, imagem 1 %32 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: passo 2, imagem 2 %32
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel: passo 3, imagem 1 %32
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
    Pergunte ao FixBot
    Comentar
  4. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: passo 4, imagem 1 %32 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: passo 4, imagem 2 %32
    • Remove the four 7mm Phillips screws holding the circuit board in place.
    Pergunte ao FixBot
    Comentar
  5. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Motherboard: passo 5, imagem 1 %32
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Anna Kihm
Membro desde: 10/13/14
965 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 2-4, Benson Fall 2014 Membro de Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Membros
Autoria de 6 guias
1Comentário do guia
What is the little dial on the circuit board on the upper right that has numbers 1 through 3 on it and it can be adjusted thank you
Thomas Clawson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 48
Ao todo: 3,136
