Ir para o conteúdo principal
Cen-Tech Seven Function Digital Multimeter . Model number 90899.
Why will the dial not move to a new position?
I am trying to turn the multimeter to another mode, in order to test voltage. The dial will not turn, so I cannot switch modes.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
There are a couple of reasons as to why the dial may not be not moving. The dial could be dirty or broken, in this case the dial will need to be removed and either replaced or cleaned. See Dial Replacement Guide. Another possible problem is that the ball bearings that are located below the dial need replacing or lubricating in order for the dial to move. See Ball Bearings Replacement Guide.
Imagem de Cen-Tech Seven Function Digital Multimeter Dial
Guia
Cen-Tech Seven Function Digital Multimeter Dial Replacement
Nível de dificuldade:
Moderado
10 - 15 minutes
Imagem de Cen-Tech Seven Function Digital Multimeter Ball Bearings
Guia
Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement
Moderado
10 - 20 minutes
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Anna Kihm será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 354
