Ir para o conteúdo principal
Lançado em 2010, o Logitech G27 é um volante eletrônico projetado para jogos de corrida de simulação no PC, PS2 e PS3.
LOGITECH G27 Racing Wheel
my g27 wheel has no force feedback and the shifter and clutch pedals don't work. The wheel works and all the buttons work. Thinking it might be the motor?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi, Regarding your wheels lack of force feedback, it could be that the motors in your wheel are either broken or stripped. However I would check in-game settings to make sure before disassembling your wheel. As for the shifter and clutch pedal I can think of only two things that would make those not work. Either the potentiometer in the shifter is broken and needs to be replaced, or the whole setup is having a connectivity problem with your gaming device. The potentiometer can be replaced relatively easily however the connection problem would be much harder to find then solve.
Esta resposta foi útil?
Pontuação 1
you're mum lol
Pontuação 0
Could be the power supply.
Pontuação 0
Adicionar a sua resposta
meemo39 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 27
Ao todo: 858
