Ir para o conteúdo principal
O Motorola Droid 4 é um smartphone fabricado pela Motorola, lançado com o Android 2.3 e com possibilidade de atualização para o Android 4.1.
damaged battery connection?
Would it have damaged my battery connection when i dropped my phone and it landed hard enough to shatter the screen and threw the battery out of it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Kip,
I highly doubt that the battery itself is at fault here. Check out the battery guide for the droid 4 here on ifixit: Substituição da bateria do Motorola Droid 4
As you can see, the battery is pretty secure on these devices, and the connection is even secured with two screws. What are some of the issues you are experiencing? If the device is not powering on, you most likely need a new LCD if the fall was hard enough to shatter the screen and make you think the battery got disconnected. As always, more information would be helpful.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kip será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 254
