Ir para o conteúdo principal
O Samsung Galaxy S3 é um smartphone com tela sensível ao toque, formato de placa, com capacidade de rastreamento ocular, armazenamento ampliado e uma opção de carregamento sem fio.
LCD screen won't light up
Hi there,
I dropped my Samsung s3 and although there is no external damage, the LCD light won't turn on and it's black, even tho I can still turn the phone off and on and can still hear when a txt etc is received.
How can I get my screen to work again?
Thanks!
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
90% your display is broken.
If you want, you can open the phone and reconnect the Display Flex Cable (Step 19):
Substituição do conjunto do painel dianteiro do Samsung Galaxy S III
Next, you need a Display assembly replacement.
Regards.
Esta resposta foi útil?
Pontuação 2
Hello i have the same problem.. but mine is with s6 edge. And also with broken LCD glass.. i cant afford to get a new LCD yet.
But i wonder if its the LCD. Or like you said the display flex cable.
Mine lights up sometimes after i press all the bottons a hundred times. But i get tired when it happen.
You think its the same peoblem??
Idk how to open my phone. So.. but i will want for someone to do it for me... but i wanna have idea of the problem so they wont trick me about what else is broken and charge me a lot. Hehehe
Thank you in advance.
Pontuação 0
Adicionar a sua resposta
Peetah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 7,114
