Ir para o conteúdo principal
Disponível a partir de setembro de 2011. Tela - 800 x 1280 pixels, 9,4 polegadas. Chipset - Nvidia Tegra de 1 GHz. Câmera de 5 MP. Sistema operacional Android, v3.1 (Honeycomb), atualizável para a v4.0.3 (Ice Cream Sandwich)
WIFI does not work
Hi,
I can't connect to the wifi at home, it detects the signal but it does not connect to it. It thought it was my wifi's home, but at work it happens the same. I also went to another person's house and the wifi does not work.
I put the password again, disconnect and connect the wifi, but nothing happened.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
polharder, has it ever worked for you? Did you change anything in your settings lately
por
Adicionar um comentário
1 resposta
Solução escolhida
Try going to an open WiFi location (an AP without any security password). See if it can connect to it (altering your AP settings; going to McDonalds or Starbucks Coffee house etc...)
If it does work then you'll need to check the case of the password as upper & lower case are different here (even unicode characters). Also make sure the password is not overly long as some devices can't parse the key longer that 10 digits/characters.
Next check what security option you are using on the AP and make sure your device can do it. As an example some older devices can't to WPA 2.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
polharder será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 26
Ao todo: 576
