Ir para o conteúdo principal
Guias de reparo e suporte para câmeras digitais da Samsung.
lens open & close same time
My samsung camera DV 150F as soon as i press the power button LENS opens & close same time and follow message appears on screenTHE ZOOM DIDNT OPERATE NORMALLY INSERT THE BATTERY AGAIN AND TURN THE CAMERA ON IF NOT WORK CONTACT THE SERVICE CENTRE.
Esta é uma boa pergunta?
Pontuação 17
Adicionar um comentário
3 respostas
Solução escolhida
Raza, first of course you want to follow the instructions given to you regarding the battery. If that does not work, it sounds like you are having issues with your lens not properly extending. You could try and clean it, check to see if it looks center when retracted. Check on here for more information.
Esta resposta foi útil?
Pontuação 3
I tried the paper shim going around between two lenses and body and lens, compressed air, allowing small amount of alcohol on q-tip on gap - and nothing would get my lens to open. Then I held in flat between my two hands and "gently" gave it a very light twisting diagonally, once in each direction. Hit the power button and it works fine now. As my gaffer used to say, "Don't force it! Get a bigger hammer!"
Pontuação 2
Try removing the battery exactly as the lens comes out.. it worked for me while all the other solutions failed.
Pontuação 1
1 comentário:
You saved my life, thanks a lot :)
por Compartilhar
Adicionar a sua resposta
Raza será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 12,182
