Ir para o conteúdo principal
What to do about damaged bezels and screen fitting?
Hi,
Everytime people ask me to repair their iPhone 5, I look at the bezel to see if there are any damages. I look for them because it is impossible to fit in a new screen, without damaging or cracking it, if the bezel is damaged.
The question is, how do you guys deal with bent bezels (iPhone 5/5s/5c)?
It is annoying when the screen cracks because of too much pressure and/or a damaged bezel.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
do you mean the frame or the plastic bezel that surrounds the screen?
For frame bends, invest in a gtool or find a local shop that will let you use theirs. The gtool is relatively new, so we will probably see less expensive similar products coming to market to compete.
if you mean the plastic bezel on the screen, these are easily replaced with new.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Ah.. I meant the aluminium (?) frame!
por
Any good sources for the plastic bezel? I haven't seen it listed here on iFixit (for the 4S at least). Not a big issue, but I have one cracked here, it is cosmetic, but would like to replace.
por
Here's what they're talking about: [produto vinculado ausente ou desativado: IF145-280-1]
por
Yip gtool is the mission
Expensive but totally worth it
Pontuação 0
Adicionar a sua resposta
Eddy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,041
