Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
How do I clean the LCD panel before reinstallation and reassembly?
I just replaced the glass on my 3G and am wondering what products I can use to clean the lcd panel itself before I reassemble as I am betting it is very important this is perfectly clean.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
You are right, it is important to make sure the LCD is clean. Anything that is stuck to it will be clearly visible when you reassemble. Use a microfiber cloth to clean off the LCD, canned air is useful too. You can find both of these at most hardware stores. It is also important to work in a clean, dust-free environment.
Make sure you do all that and you should be fine.
Good luck!
Esta resposta foi útil?
Pontuação 5
4 comentários:
+ Ralph
por
So, I just tried the microfiber cloth (used brand new one) and it got rid of any dust but there was one fingerprint on it that just seems to have been smeared around :(. Any idea if I can use any sort of cleaning solution (alcohol based?) or will it wreck my screen?
por
Is this on the LCD panel or the front glass?
por
I have good luck with a qtip and rubbing alcohol over 90%
por
you can replace the spring with a flintstone spring of a disposable lighter - of course only a short part of the spring. cut the spring to the lenght you need and solder it to the logic board. maybe you should stretch the spring a little bit before you cut it, that way it will be a little bit more flexible.
Pontuação 3
1 comentário:
The actual LCD panel not the front glass :( unfortunately.
Pontuação 0
1 comentário:
I would avoid cleaning solution, just try again with the cloth
por
I used yet another clean cloth and that seemed to get rid of everything. Re-assembled the phone and the touch screen works and looks great! But now my home button doesn't work :(. After re-disassembling I found one of the tiny sensitive little spring contacts for the button had broken off inside the phone. I think the only way to fix it is to solder a pin about 1/16th inch long onto the contact to get it to press against the other contact point on the phone. Otherwise I could tear off the digitizer and glass I just replaced and replace the whole home button assembly...
Pontuação 0
Adicionar a sua resposta
Alex Williams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 19,419
