Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Perguntas Visualizar todos
Installed new broadcom card... now no bluetooth
So I just installed a new Airport/bluetooth card i(4.0 ie BCM94331PCIEBT4CAX) into my Early 2011 Macbook pro... when I turn my computer on... I was happy to see my Wifi Working but it says no bluetooth hardware detected.
Since there is WIFI doesn't that the card works?
Or is it a defective card?
Could I have not attached something properly?
Or is it a software issue???
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
David, I would dry a PRAM reset before declaring it defective. Sometimes this forces the machine to recognize new hardware. Also, what do you see under System Profiler under bluetooth? Anything there?
Esta resposta foi útil?
Pontuação 3
1 comentário:
I'd also reset the SMC.
por
I just tried to no avail
It also shows nothing under system profile
Pontuação 1
1 comentário:
double check if the bluethoot connector is well inserted in its socket.
por
Adicionar a sua resposta
David Burkholder será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 307
