Ir para o conteúdo principal
Guias de reparo para laptops fabricados pela Dell que podem ser usados para fins escolares ou profissionais.
Not detecting the battery
Hi,
I have a Dell studio 1555 laptop, Problem is the battery is not charging up . On further investigation I did the following
I replaced the new battery.
I bought a new charger (original)
I replaced the power jack with a new one
still its not charging could this be a faulty Mother Board?
Thanks for the help.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
As you are saying already had replaced everything it means there is problem with charging power unit into motherboard. So go to nearest Dell service store check by them. Never try to do anything by yourself in motherboard it may cause critical problem.Thanks.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
zasid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 389
