Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
4.8mm Standoff Not working
So i am trying to put my iphone 4 back together, but when i try to screw the screw that holds in the grounding clip on the wifi antenna, it will not go in. Can i buy another standoff somewhere for cheap? Preferably on ebay. I have seen some screw sets but I dont know if the standoff is the 3.6 or 4.8mm. Its a iPhone 4 Verizon.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hi
The stand off is 4.8mm. http://www.ebay.com/itm/NEW-iPhone-4-4G-...
The screw will be in that kit, you cant buy the screw by itself.
I have done countless iPhone 4 and 4s screen replacements the wifi will still work with out the ground clip (but its not recommended to not have one) Do not use the phone for a long period of time without the ground clip. I would try to get that screw asap so you don't do damage to the wifi connector.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Vlad Nikolayev será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 282
