Ir para o conteúdo principal
O ASUS PadFone X é um smartphone Android LTE Full-HD de 5 polegadas revolucionário, que pode ser facilmente transformado em um tablet LTE Full-HD de 9 polegadas. A ASUS lançou o dispositivo em junho de 2014, identificado pelo número de modelo T00D.
Why does my battery drain so quickly?
On other smartphones that I have had, the battery would last a day. However, with my Padfone X, the battery only lasts a few hours before it needs a charge. Is there something wrong with my phone? Do I potentially need another battery?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
There are several potential factors that could greatly reduce your battery life. The display uses the most battery power, so to start it is recommended that you turn down the brightness. Also check for any applications that you are not using, but are still running in the background. Close these applications. If you are not using WIFI, you can turn it off so your phone is not constantly searching for a signal. After making these changes, if your battery still
drains quickly, then you may simply have to replace the battery.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Andrew Smith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 1,068
