Ir para o conteúdo principal
O Samsung Galaxy Light é um dispositivo Android lançado em outubro de 2013 para a T-Mobile, com GPS, slot para cartão microSD e 8 GB de memória.
My phone will not charge...
My phone will no longer charge, I am not sure if it is battery failure or my charging port.
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
This could be an issue with your charger or phone charging port, start with trying another charger. If this did not work try cleaning out the port on the phone, if it still doesn't work you will need to replace the micro USB port in your phone to do so follow this link (Samsung Galaxy Light) to see step by step how to replace your port.
por Compartilhar
Adicionar um comentário
1 resposta
This could be an issue with your charger or phone charging port, start with trying another charger. If this did not work try cleaning out the port on the phone, if it still doesn't work you will need to replace the micro USB port in your phone to do so follow this link (Samsung Ga...) to see step by step how to replace your port.
Esta resposta foi útil?
Pontuação 0
1 comentário:
There no guide via your link.
por Compartilhar
Adicionar a sua resposta
Paul Goyette será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 370
