Ir para o conteúdo principal
Graphics card is bad.
I have a MacBook Pro 15" (Model A1211) 2.16 GHz. Just need to know if the Graphics card is located on the logic board? if not, where is it?
Esta é uma boa pergunta?
Pontuação -1
3 comentários
This model did not have the nVidia GPU. GPU failures are very rare on your machine. Have you tried using an external monitor?
por
I have not tried an external monitor. When I start up my MacBook I can't even see my user login. Will I be able to still get the computer to display on an external monitor if I can't get past login?
por
Tried external monitor. All I have is blue screen on both laptop and monitor. Disconnected external monitor and now all I get on laptop is blue screen on start up . Any advice?
por
Adicionar um comentário
1 resposta
Solução escolhida
Yes it is soldered to the logic board.
Re-flow is a "shade tree fix" it may work, may not work. If it works it may work for just a little while or for quite a while.
A DIY re-flow is risky - one person here recently baked a logic board in an oven and had components fall off! Since they had no pictures they had no clue where the parts came off.
A "professional" repair or re-flow from a service on e-bay is a different animal... but only you can do the cost analysis .
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Tim Machgan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 443
