Ir para o conteúdo principal
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Can a single memory be installed?
Example, only one 8GB RAM installed and the other slot kept empty for future upgrade. Any technical or performance implications?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Yes with no negative impact or ramification other than what you're doing. As long as you're not using RAM hungry apps (Video, Photo, gaming etc) you'd never see the difference. It doesn't take much RAM for email, word processing or web browsing.
If you loaded 8GB in each side you'd have the Max RAM... more RAM - increased performance Mac OS X loves RAM. Short of buying a new Mac or a processor upgrade, adding RAM is the best way to improve Mac OS X performance. Install the maximum amount of RAM that your Mac will accept and your budget will allow.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks very much
por
Adicionar a sua resposta
Suraj Shastri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 192
