Ir para o conteúdo principal
How to fix low VRAM?
Hi everybody,
Many thanks to Machead3 for your answer ! Well, you're right, the Macbook Core 2 Duo Model A1211 is built with 128 Mo of VRAM.
But as I said, the graphic chipset has been replaced after the overheating, but now, the bad thing is that I have just 5 Mo of VRAM instead of 128 Mo.
Is the VRAM comes from graphic chipset or from memory (RAM) modules ? Or perhaps from another component on the logic board ?
Many, many thanks to all the community for all answer about it.
Kind regards from France
Yves
PS: I'm sorry if I make any mistake... I'm a newbie for posting on the site.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Without knowing what GPU/VGC you put in the box I can't answer your question exactly. Generally however "shared VRAM'' is a more recent development and most likely not to be a part of your machine.
The VRAM is either on the card, or when not on the card comes from the machines RAM, only since about 08 has there been both/or switching of VRAM possible.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
yjusserand será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 679
